주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년에 출시된 올인원 카메라로, Wi-Fi, Bluetooth 및 방수 기능을 갖추고 있습니다. 이 카메라는 HERO+ LCD 모델과 달리 터치 스크린 디스플레이가 없습니다.
gopro won't do anything
hero HD LCD just quit working won't turn on, charge nothing just quit one year old what to do?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Please press and hold the Power/Mode button on the front of the camera for about 10 seconds, then release it.  This acts as a rest and in most cases, this makes your camera power ON again if the battery has a charge.
  1. If the camera doesn't power ON, let's try charging the battery.  Please use the supplied GoPro USB cable to connect your camera to a USB port directly on your computer or to a USB wall charger that outputs 5V and 1A.  Once it's connected, you should see a red LED light up on the front of your camera within no more than a couple of minutes.  If you do not see a red LED illuminate on the front of your camera, please try pressing and holding the Power/Mode button for 10 seconds while it is still connected to the USB cable.  If the camera still doesn't power ON, please try these same steps using a different USB cable and USB port or charger.
  2. When the camera is connected to the USB cable and USB port or charger, you should see the red LED light up on the front of the camera.  This indicates that your camera is charging the battery.  With the front red LED lit up, your camera should reach a full charge in 2 hours if connected to a wall charger that outputs 5V and 1A.  If connected to your computer's USB port, it may take up to 4 hours to reach a full charge.  Once the red LED shuts off, your camera's battery has reached a full charge
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
robert m dykes 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 27
전체 시간: 672
