주요 콘텐츠로 건너뛰기
The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
299 질문 전체 보기
Screen stopped working after replacing digitizer
Just replaced digitizer on iPad Air. Everything worked at first. 20 min later, random places on screen were being activated without being touched. Then a few minutes later the home button stopped working. Not sure what it could be. I took it back apart and checked connections, now the screen and home button are unresponsive. Any suggestions? I think it is a defective digitizer but I could be wrong.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
The most likely cause of your problem is a damaged or defective digitizer. You can inspect the flex cables on the digi to see if there are any tears. Also look at the connectors, both on the flex and on the logic board to see if any pins are damaged.
Contact your vendor or supplier if there is no damage to see if you can get a replacement or refund.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Robert Brotzman-Smith 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 68
