주요 콘텐츠로 건너뛰기
A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
1697 질문 전체 보기
My ps4 switches on but with no signal
My ps4 switches on completely but with no video at all. I have switched TVs, changed hdmi ports, changed hdmi cables and even a month or two ago got a completely new hdmi port on my ps4 put in and it worked fine until yesterday. Ive even tried going into safe mode but no luck. My ps4 was on and th light was blue etc. So I decided to put my headphones in and I can hear in my headset the menu and all the noises when navigating. I really need some help as soon as possible.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 2개
가장 유용한 답변
if you replaced your HDMI port yourself, which got it working, then it stopped working again, it could very well be that the HDMI port either went bad, got damages, or pulled a pin off the board.
if you have good experience with soldering, Attach anotherone yourself. if you dont solder often, i suggest getting it repaired through a store.
if the HDMI port doesnt fix the issue, run through a reflow on the GPU. This may getit working.
if it continues to fail, then you are looking at a board failure. in this case, replacing the device is your best option.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
The first thing you need to do i go to best buy and buy a new ps4 hoped i helped
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
== Heading text== == Heading text ==== == Heading text ==== == Heading text ==== == Heading text ==== == Heading text =='bold text' == == == == == ==
댓글 달기
귀하의 답변을 추가하세요
Ihsaan Khan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 9,616
