주요 콘텐츠로 건너뛰기
Repair guides and support for smartphones manufactured by Doogee.
71 질문 전체 보기
Screen gone half black
I have a doogee y100 plus, it fell several times before but it remained unharmed, until this time, it fell from my bed, and Immediately after I picked it up, I turned it on, and the right half of the screen was black, and on the other side (which still almost normal) there is some vertical semi-transparent white lines that looks related to icons (some only shows when I enable some functions such as bluetooth and wifi) , but it is still responsive, though i can't see anything under the black part I can use it (I can use keyboard and can open apps even under the black)
I tried to restart it and remove the battery but nothing changed, it even showed on the logo screen.
The technician said that the problem is from the LCD screen and that I need to change it.
but I just hope he's wrong because I can't find any replacement parts for this phone in my area.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@chocola going by your description alone, it does sound like a broken LCD. You can post some pictures of what your screen shows with your question. Use this guide for that 기존 질문에 이미지 추가하기 That will allow us to see what you see. Looks like the display assembly is available at places like this and others.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Rayane 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 6
30일 전: 12
전체 시간: 175
