주요 콘텐츠로 건너뛰기
The Golf Mk4 was first introduced in August 1997, followed by a notchback version (VW Bora or, in North America, again VW Jetta) in August 1998 and a new Golf Variant (estate) in March 1999.
35 질문 전체 보기
Automatic transmission problem - delayed shifting
The problem is that when I start driving I spidometer stays at 0, and then at some point it "jumps" and shows real speed, in that moment the transmission shifts to next shift.
Also I hear a lot of banging when shifting, so do you have any idea what is happening? One more thing, when I connect car to diagnostics I get g68 error.
Sorry for my bad English
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
There is a TSB 01-07-09 for your vehicle covering the G68 speed sensor. A faulty connector wiring is apparently the problem.
Go here and you can read about it yourself it also instructs you how to fix it. But at least it will give you some good information.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Thanks a lot for response. I've tried to find where the sensor is, but unfortunately I couldn't find it, I've tried on the internet and also with autodata 3.38, but nothing. Can you help me somehow?
Try this thrhttp://forums.ross-tech.com/showthread.p..., and read through it. Also has a diagram and written location and instructions.
댓글 달기
귀하의 답변을 추가하세요
Enis 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 2,377
