주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Golf Mk4는 1997년 8월에 처음 소개되었으며, 1998년 8월에는 노치백 버전(VW Bora 또는 북미에서는 다시 VW Jetta로 명명)이, 1999년 3월에는 새로운 Golf Variant(에스테이트)가 뒤를 이었습니다.
Automatic transmission problem - delayed shifting
The problem is that when I start driving I spidometer stays at 0, and then at some point it "jumps" and shows real speed, in that moment the transmission shifts to next shift.
Also I hear a lot of banging when shifting, so do you have any idea what is happening? One more thing, when I connect car to diagnostics I get g68 error.
Sorry for my bad English
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
There is a TSB 01-07-09 for your vehicle covering the G68 speed sensor. A faulty connector wiring is apparently the problem.
Go here and you can read about it yourself it also instructs you how to fix it. But at least it will give you some good information.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Thanks a lot for response. I've tried to find where the sensor is, but unfortunately I couldn't find it, I've tried on the internet and also with autodata 3.38, but nothing. Can you help me somehow?
의 공유
Try this thrhttp://forums.ross-tech.com/showthread.p..., and read through it. Also has a diagram and written location and instructions.
의 공유
댓글 달기
답변을 추가하세요
Enis 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 16
전체 시간: 2,844
