주요 콘텐츠로 건너뛰기
Repairs guides for the Fender Frontman 15r, a small, 15 watt, practice guitar amplifier. Model number: 022-1500-000.
12 질문 전체 보기
2nd gain channel distorted
2nd channel became distorted after hitting a big cord the gain channel is affected
when the gain is off it works fine both channels i am a hobby tech i can read schematics i have had this amp apart once before for a hum problem this turned
out to be a ground conn on the board fixed it all was good i suspect a capacitor
has bit the dust in the gain section before i open it up i wonder if anyone has had this problem and what the fix was
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hi,
Here is a link to the service manual for your amp.
To download the manual, when the sentence below the Document preview box changes from This file is downloadable free of charge: ...processing... to This file is downloadable free of charge: Get Manual, click on the Get Manual as this is the download link.
Be patient. It takes a little while to find the file.
If it it only affected when the drive select switch is operated, check the circuit around the U2A / U2B amps section. (make sure you're looking at the 15R cct and not the 15G cct).
Hopefully this is of some help
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
w1jonjc21 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 5
30일 전: 8
전체 시간: 370
