주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
Repairing firmware
Do we have anyone with experience in repairing firmware? I have disassembled many, replaced bad drives or ports, etc. I am looking for any Xbox 360 lessons-learned, knowledge, help hints, and any information on "bricking" and "unbricking".
Your assistance is greatly appreciated.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 7개
선택된 해법
1 Red Ring is a general error
2 Red Rings is overheating
3 Red Rings is hardware failure (ususally a bad joint between the GPU and Logic Board)
error codes are ususally not easy to fix, there are error code keys on the web, but there are tons of error codes.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Lazer setting off.YouTube it.easy fix.
댓글 달기
가장 유용한 답변
ususally, xbox's don't get bricked, they have onboard firmware, and the firmware is not accessable externally, if you are trying to remove the NXE, it isn't possible, if you want to try, you may be able to trick the console into downgrading the firmware, by putting a firmware update file on the hard drive via special adaptor, but annother thing to know is that the xbox dvd drives are keyed to the motherboard that they shipped with, so if you get a new logic board, make sure that it comes with a DVD Drive
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Thank you very much for the information...I wondered if they were keyed. Any info on red rings (1-3), error codes, and RROD. I am still learning. Thanks, Kelly
댓글 달기
i found this really helpful.
http://www.llamma.com/xbox360/repair/Xbo...
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Lots of good stuff here. +
댓글 달기
These are the ones I use whenever I get to tinker with an XBox or just to keep mine alive. I do like xbins since it does have the proper software for remapping as well as firmware issues. Comes in handy....good luck.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Sorry forgot a few things :) http://www.xbins.org/
http://www.360-hq.com/xbox360/hardware/ that is what I meant to attach...
댓글 달기
ok,my xbox360 starts screen freezes. scanable look. but with out hardrive it run disc fine. if idea.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
HDD Problem, try replacing it.
댓글 달기
Hi Anibal my Xbox 360 not how open work happen know not
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Not work open each much time Xbox 360
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Not work Xbox 360 open not
댓글 달기
답변을 추가하세요
aquabluekt 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 23
전체 시간: 6,619
