주요 콘텐츠로 건너뛰기
The Stylo 2 (model number LS775), the second iteration of the Stylo series, is manufactured by LG and was originally released in April 2016.
81 질문 전체 보기
Sound is not working
I only have sound when using headphones. How do I get my speaker to work?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 3개
I have to same problem it say my headphones are in but they are not
It shows headset logo on screen and sound is not working
I am having the same problem with my LG Q Stylo+. If anyine has anyrhing to help please contact me at aedanouellette@gmail.com
댓글 달기
답변 5개
가장 유용한 답변
Tried various fixes I found online for the same problem with my LG Stylo2. This is what worked for me....Remove the back cover of your phone and push on the speaker (left bottom) a few times. All of a sudden I have sound again. Loose wire likely cause inside speaker!! Hope this works for you.
해당 답변은 도움이 되었습니까?
점수 7
댓글 9개:
Thank you!!... I tried all sorts of things to get my speaker working again!... I almost did a factory reset on it.. Who would've thought something so simple would work! Lol.... Thank you again for your advice!
Thank you! This worked.
I am so glad. Did not know if this would last but 4 months later and mine is still working with no problems. Glad I could help.
It worked for me too!!!
and anotha one!!!!
댓글 4개 더보기
댓글 달기
You got to take the back off and screws out take off souronding plastic molding there is 2 pins connected on the speakers itself they must be touching the tape or ribbon perfectly or you will not get sound go to YouTube for video on how to take phone apart properly
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Had the same issue took it all apart & put it back nothing, sprayed the contact cleaner ,pulled the speaker out tested it outside it was good, then i saw where the speaker sits if you push the cover you'll hear a click that is the notch that pushes the cover & makes the contact.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
thanks so much i try this way my problem was resorve .
The push and click worrrrrked! Thank you so much!
댓글 달기
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Pushing of speaker repeatedly from left to right or from right to left by removing just back cover
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Geneva Campbell 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 14
전체 시간: 12,648
