Sound is not working
I only have sound when using headphones. How do I get my speaker to work?
좋은 질문입니까?
좋은 질문입니까?
Tried various fixes I found online for the same problem with my LG Stylo2. This is what worked for me....Remove the back cover of your phone and push on the speaker (left bottom) a few times. All of a sudden I have sound again. Loose wire likely cause inside speaker!! Hope this works for you.
이 답변이 도움이 되었나요?
Thank you!!... I tried all sorts of things to get my speaker working again!... I almost did a factory reset on it.. Who would've thought something so simple would work! Lol.... Thank you again for your advice!
Thank you! This worked.
I am so glad. Did not know if this would last but 4 months later and mine is still working with no problems. Glad I could help.
It worked for me too!!!
and anotha one!!!!
You got to take the back off and screws out take off souronding plastic molding there is 2 pins connected on the speakers itself they must be touching the tape or ribbon perfectly or you will not get sound go to YouTube for video on how to take phone apart properly
이 답변이 도움이 되었나요?
Had the same issue took it all apart & put it back nothing, sprayed the contact cleaner ,pulled the speaker out tested it outside it was good, then i saw where the speaker sits if you push the cover you'll hear a click that is the notch that pushes the cover & makes the contact.
이 답변이 도움이 되었나요?
thanks so much i try this way my problem was resorve .
The push and click worrrrrked! Thank you so much!
이 답변이 도움이 되었나요?
Pushing of speaker repeatedly from left to right or from right to left by removing just back cover
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 3
지난 30일: 21
전체 시간: 13,184
댓글 3개
I have to same problem it say my headphones are in but they are not
Jasmine Benedetto 의 공유
It shows headset logo on screen and sound is not working
ojewezt198 의 공유
I am having the same problem with my LG Q Stylo+. If anyine has anyrhing to help please contact me at aedanouellette@gmail.com
Aedan Ouellette 의 공유
