주요 콘텐츠로 건너뛰기
LG에서 제작한 터치스크린 스마트폰 모델 번호 VS980는 2013년 9월에 출시되었습니다.
185 질문 전체 보기
no response from touching screen
I touch my screen and nothing happens. The home button - none of the bottom icons respond to touch. What is the remedy?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Hi @bunjee ,
It seems as though there is a problem with the digitizer (touchscreen).
I suggest that first you try connecting a USB mouse via an OTG cable adapter and use it to navigate through the phone so that you can backup the phone, if you haven't already done this recently. Make sure that the phone's battery is fully charged as it will be supplying power to the mouse.
Here is a link to a video that shows how to replace the digitizer in your phone.
Here is a link that shows suppliers of the part. It is not a recommendation to use them. It is shown to give an idea of the cost of the part. There are other suppliers online that may suit you better. Just search for LG G2 digitizer part to get results.
If replacing the digitizer seems too daunting a task, contact a reputable, professional mobile phone repair service and ask for a quote to repair the phone. You already have an idea of the cost of the part. ;-)
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
What make and model phone is it? Was your phone dropped recently or has it been subjected to anything that would cause it to malfunction?
It sounds like a faulty or damaged digitizer, but without knowing what make/model the phone is or history of the device, it is difficult to determine.
Also I am unclear about what the home button is doing. Is it working or not?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
The phone in question is an LG G2.
It has never been dropped or abused in any way.
The icons at the bottom of the screen do not respond to touch.
In fact, very little responds to touch.
Please advise.
댓글 달기
귀하의 답변을 추가하세요
Danny 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 9
전체 시간: 159
