주요 콘텐츠로 건너뛰기
A color version of the Nintendo Game Boy, released in 1998. Repair of this device is straightforward.
74 질문 전체 보기
Why won’t my Game boy turn on?
My Game boy color used to work fine but then it wouldn’t turn on. I figured out that I have to fiddle with the switch a little bit in order for it to turn on but it still won’t turn on perfectly. What do I do?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Hi @colorwave ,
Here are two links that may be of some help.
This one describes what to do if the problem is with dry solder joints on the switch. Scroll down to the section dealing with the power switch (it starts about halfway down the page) and check if it applies in your situation. (It is the link which is embedded in the link below).
This one describes how the problem can be solved if it is not a dry joint problem and you need to replace the Power switch.
Between the two you should hopefully be able to solve your power switch problem
Here is a link to the ifixit Game Boy Color Motherboard Replacement guide, which should assist you in gaining access to the motherboard so that you can check out which solutions you need to use from the links above.
Hopefully this is of some help
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
James Clark 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 8
전체 시간: 2,973
