주요 콘텐츠로 건너뛰기
The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
116 질문 전체 보기
240D headlight switch accidental modification
hello, i am having a hard time finding a picture of the wire connections for the headlight switch. the original owner had modified the switch because it broke.. — i unscewed the wires from the switch and forgot to take a picture of how they were connected originally. i managed to get the headlights working but my reverse lights, speedometer lights, and console lights are not working. — can anyone attach a picture of how they have their wires connected? my car is a 1981 240d mercedes
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
W123 main light switch does not control reverse lamps. If they are not working, check fuse 14 (it also powers the horn, so test your horn before removing fuse box cover). A failing neutral safety switch is common cause of inoperable reverse lamps. Instrument cluster (gauges, speedometer and clock) are likely not working because the dimmer is corroded or damaged. Try twisting the dimmer knob back and forth (it is next to Brake warning lamp. The knob is also the button one presses to reset the trip odometer). Dimmer does not affect the gear-shift and air-conditioner lamps (the latter is next to blue temperature knob). If either or both of these are lit, but cluster is dark, this likely indicates a failed dimmer control. Some people bypass the dimmer, others attempt to repair it while brave folks pay the bucks for replacement part. Its up to you as to which method suits the need. FYI: license plate lamps are also fed by power that illuminates the gear-shift and air-conditioner lamps, so looking at license plate lighting will help validate main light switch wiring.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Michal Harvey 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 6
전체 시간: 372
