주요 콘텐츠로 건너뛰기
2006 중반기/ 모델 번호 A1181 / 검정 또는 흰색 케이스 / 1.83 or 2.0 GHz Intel Core Duo 프로세서.
Doesn't turn on after disassembling for dust cleaning
Hi,
It is not the first time I disassemble a computer. I have done it many times with my MacBook Pro.
But this time, I have done it for the first time on a Macbook A1181. I followed this guide to access the fan: MacBook Core Duo Fan Replacement
After reassembling the computer doesn't respond when I press the switch... :-(
I have checked the upper case cable (step 12) but it looks fine.
What should I do?
Thanks
Jerome
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Finally, I solved the problem by changing the upper case cable.
Unfortunately I couldn't buy on iFixit. I found it there: https://www.amazon.it/gp/product/B01MSH3...
And then followed this guide: MacBook Core Duo Upper Case Cable Replacement
Thanks for the help !
이 답변이 도움이 되었나요?
점수 1
댓글 달기
가장 유용한 답변
I think you hit it on the nose. Step #12 MacBook Core Duo Upper Case Replacement
That connector can be tricky.
To confirm, try disconnecting the battery and mag-safe adapter. Press and hold the power button for 10 seconds. Reconnect and see if you get a spontaneous reboot.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
I did what you say. Unfortunately, it didn't change anything.
댓글 달기
답변을 추가하세요
poissonjerome 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 242
