주요 콘텐츠로 건너뛰기
모델 A1502 / 4MB 공유 L3 캐시 2.6 GHz (Turbo Boost 최대 3.1 GHz) 또는 2.8 GHz (Turbo Boost 최대 3.3 GHz) 듀얼-코어 Intel Core i7 프로세서.
494 질문 전체 보기
No output audio on MBP Retina, only startup chime
My MBP Retina 13" 2014 A1502 has no audio output device. Only on startup do I get the start up chime, then I have no output from loudspeakers as well as from the headphones jack.
What I've tried so far:
  • Reset NVRAM, SMC reset
  • Format and Reinstall of OS X El Capitan 10.11
  • Create new admin user
  • Startup from Safe mode
  • Apple diagnostics show no error
When sending audio via bluetooth to a wireless speaker works fine, so I think the soundboard is OK. Also the systems loudspeakers seems to be OK, as I can hear the startup chime.
Any idea?
Thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
If there is no red light inside your headphone jack, I would check System Preferences / Sounds / Output to make sure Internal Speakers are selected.
If there is a red light inside your headphone jack, it means your Mac thinks an audio plug is inserted.
I've read of people wiggling a headphone plug or a toothpick inside to reset the internal switch.
If the switch itself is damaged, the audio port integrated into the main logic board; and the whole board would need to be replaced. It's an expensive repair. MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement
Good luck.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
I have no Output Device to choose on that list. What red light do you mean?
he is talking about a red light from inside your headphone jack
Yes, sorry I wasn't more specific. If you look into the port you usually plug-in headphones or speakers, there is a red LED that will light up if the hardware thinks a plug is inserted.
댓글 달기
귀하의 답변을 추가하세요
Santiago 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 6
전체 시간: 302
