주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mercedes-Benz W126은 1979년부터 1992년까지 메르세데스-벤츠에서 생산한 S-클래스 자동차 시리즈입니다. W116 라인의 후속 모델로 1979년 9월에 첫선을 보인 W126은, 독일어로 '특별한 등급'을 뜻하는 'Sonderklasse'의 약칭인 S-클래스라는 명칭을 공식적으로 사용한 두 번째 세대입니다. W126 세단은 초기 직렬 6기통, V8 및 터보차저 디젤 엔진 사양으로 출시되었습니다. 1981년 9월에는 C126 2도어 쿠페 버전이 추가되었습니다.
300SD won't start unless terminal box is shorted
Hi everyone,
I picked up a ragged 1982 300SD over the weekend for a great price. However, the other morning I couldn't get it to start. The starter wasn't turning over, but the car had power and a good battery. I couldn't hear a starter solenoid click either. From my research online and owning a couple of W123s, I tried shorting the two outer terminals of the starter terminal box with the key in the run position and it immediately fired right up.
What part could be going bad? The starter is new from the prior owner, so the only other ideas I could think is that either the neutral safety switch is bad or the ignition switch on the rear of the ignition assembly is bad. Are there any other parts I might want to look at? If all else fails, I'll install a push button start in conjunction with the key, but preferably, I'd like to fix the problem. Thanks!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Do the dashboard indicators light up when you turn the key? I forgot, was the SD a diesel?
Yes the indicator lights pop up. The glow plug light comes on for 10 seconds and then shuts off, and the battery light comes on until the car is started. And yes, it's the diesel. The starter sounds very healthy and the car starts up immediately when you short the terminal block.
댓글 달기
답변 1개
선택된 해법
Sounds like you are on track with your diagnosis of neutral or start contacts in key switch. Check for voltage on the start lead when you key the start position (you will need an assistant unless you have very long test leads that will reach into the drivers position). If no voltage try jiggling the shift selector a bit while keying to start position. I would check for voltage at the park/neutral switch (key side of circuit or both if you are not sure) while keying to start position. Still no voltage? .... it is the key switch in all probability and that will be a pain to change out I expect. Maybe a discretely mounted dedicated start button is going to be much easier to do in that case.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Turns out the neutral safety switch is bad. I'll get around to replacing it eventually, but I'll be mounting a push button start in conjunction with the key. Thanks!
댓글 달기
답변을 추가하세요
Jasen Friedle 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 21
전체 시간: 2,572
