주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
5s Blue Screen of Death Bootloop
Problem description:
The phone is stuck in an apple logo boot loop with Blue screen of death cutting it off.
I can break the boot loop if I leave the battery disconnected for some time, once I plug the battery back in and let it boot up it boots up fine.
Then if I switch off the phone and try to turn it on again it's stuck in the BSOD boot loop.
Then again to get it working I have to disconnect the battery again and do the above.
What I've checked:
- Checked screw holes for long screw damage, no damage visible there
- Tried booting with front camera, rear camera, charging port, antennas unplugged
- Tried booting via DC Bench power supply adapter
What I am going to do:
- Replace tristar charging chip (U2)
Should I try anything else first before doing so?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
what about a nand reflow
I don't like reflows, I'll do tristar first.
댓글 달기
답변 1개
선택된 해법
Okay, problem solved, U2 Tristar replacement did the trick!
So for anyone with exact same symptoms on 5s, get tristar replaced to see if that helps.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Hi @benjamen50 ,
Seems like 'going with your gut feeling' is the way to go.
Cheers.
댓글 달기
답변을 추가하세요
Ben 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 519
