주요 콘텐츠로 건너뛰기
Announced in August 2017년 8월에 발표된 Galaxy Note8을 회수된 Galaxy Note7의 후속 모델입니다. Note8은 대중이 구매할 수 있도록 2017년 9월에 공개되었습니다.
148 질문 전체 보기
Broken back glass and charging port
Where can i get oem adhesive
, Glass and charging port for unlocked note 8? And did they use uv glue? Acrilic or eco? I would like to maintain as much water resistance as possible assuming i dont mess it up getting to the port. And do i need to replace the camera \ print reader glass \ adhesive? And should i remove all old adhesive? Or leave it in?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Thank you for the explanation now if i could figure out what type of glue was used and if there are any precut pieces covering all needed areas or i just wing it or use 1 solid piece covering whole back w cut outs for sensors? The barametric preasure test was really helpful and have just the device to test it in.
You can get the oem adhesive here.
댓글 달기
답변 1개
가장 유용한 답변
UV glue is only used to adhere the glass layer of a screen to the LCD (basically laminated screens).
To maintain water resistance as best as possible, remove all old adhesive that has been separated and replace them accordingly.
To test water resistance without exposing the phone to liquids you use the test menu and check the barometric pressure reading. Applying some pressure, not too much of course you don't want to damage your phone from pressure it should go up and gradually go down upon release of pressure.
Now the expected pressure will vary depending on the phone model, you'll have to search the internet up on that.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
Patrick F Mclendon 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 3
전체 시간: 153
