주요 콘텐츠로 건너뛰기
Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
227 질문 전체 보기
Showing less than 20GB storage
I've restored my 20GB 4th Gen (A1059 model) ipod although the memory on the ipod and on windows XP is now reported as being 3.55GB!
Have tried to reformat, HDD scan in diagnostic mode, etc. and all tests say okay. Still 3.5gb though...
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
I have had a similar issue because of bad sectors on my drive. You may have to replace your HDD. You will not have to reformat the drive when you do a restore through iTunes. That actually prepares the drive for use in your iPod it "formats" and transfers the firmware to your drive.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Okay thanks, looks like I'll have to reconsider a new drive - probably pick one up quite cheaply.
Again, thank you.
Carl
You are welcome and the drives are relatively inexpensive on eBay. Good Luck
댓글 달기
Hello!
Answer's a bit late... over 2 years, but I thought it may be useful to others having similar issues.
I mainly work with these iPods and over time I noticed this problem was recurring over a large amount of hard drives. So I decided to purchase a 1.8" IDE to USB adapter. They allow you to connect the hard drive directly to your computer without the use of the iPod.
Doing so showed that the hard drive needed formatting as it was damaged. I formatted and then again it displayed the same hard drive size around 3-5GB.
I then tried a more drastic restore, go to control panel, then administrative tools, then computer management, on the left you will see a drop list of options, go to storage then disk management. Here my hard drive was displayed as it's real value of around 18-19GB but 14-16GB of it was unallocated.
You can allocate it using windows but I already had a program that manages your Hard drive called Mini Tool Partition Wizard so I loaded that up and there it was again, the same unallocated space. I deleted the 3-5GB that was allocated making it 17-19GB unallocated. Then you allocate it. Go back into my computer and you should now see the hard drive with it's real value, Quick format it to set it back to the allocated letter windows prefers. Insert it back into your iPod and connect it to your computer to restore using iTunes.
You'd be surprised how many iPod hard drives I get just needing this simple fix.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Carl 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 8
전체 시간: 705
