주요 콘텐츠로 건너뛰기
The third generation of the Apple iPad, released on March 16, 2012. Full 4G and Wi-Fi model repair guides. Repairs require heat and careful prying. Model numbers: A1416, A1430, and A1403.
20 질문 전체 보기
Tear down battery replacement
Instead of using microwave to heat pry tool are there dangers using a heat gun?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
Thanks to those who answered.
댓글 달기
답변 2개
선택된 해법
Hey Wayne,
There are definitely dangers in using a heat gun but it has been the industry standard for softening adhesive for part removal for years. Those dangers primarily being heating parts of the device that you do not intend to heat. If the "pry tool" you are referring to is the iFixit iOpener, then I would highly recommend using that. It is a fantastic tool for only applying heat to the areas that you intend to do so on and it has been a joy for me to use on past repairs.
No more adhesive battles! With our iOpener, you can quickly and easily remove glued components in electronic devices whether you're a repair professional or beginner. Apply gentle, even heat to loosen the adhesive holding smartphone, tablet, and laptop case components and batteries. 이미지
제품
iOpener
$17.99
이 답변이 도움이 되었나요?
점수 2
댓글 달기
가장 유용한 답변
I'm thinking you are talking about the bag that you heat in the microwave for apply heat to the glass. It';s an OK tool but slow and probably very good for a beginner. Using a heat gun takes some practice. It is very easy to over heat. On a product with an LCD-LED display, overheating and damage the display and you get white areas. I am speaking from experience because I have done it. On a MacBook Pro you can melt the clutch cover, melt the rubber gasket. I like to soften one corner then put a plastic card or guitar pick in. That puts upward pressure on the glass. The I slowly heat the glass closest to the pry oil it starts to release. I am allways moving the heat back and forth to prevent hot spots. As it comes loose I insert more picks to help hold it open and so it will not restock as it cools back down.
이 답변이 도움이 되었나요?
점수 4
댓글 달기
답변을 추가하세요
Wayne Wishart 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 76
