주요 콘텐츠로 건너뛰기
The Stylo 2 (model number LS775), the second iteration of the Stylo series, is manufactured by LG and was originally released in April 2016.
81 질문 전체 보기
How do I run audio from my phone through my car radio?
I have a 2003 Toyota with its standard car radio. Is there an adapter I can buy that will allow me to run audio from my LG Android Stylo 2 phone through my car radio or do I need to buy a new radio?
Update (03/22/2018)
That's a Toyota Camry. Sorry for the omission.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
Hi @larry_yurdin, there are some ways... some might use 3.5 mm audio jack to FM transmitter.
you only need to tune to the unused FM and set the transmitter to the frequency....
not sure if this is legal to use at your area.
or some 3rd party modification
댓글 달기
답변 2개
가장 유용한 답변
Hi @larry_yurdin ,
Here is another option that you may wish to consider.
This is an example only. It is not a recommendation to use the supplier. There are other suppliers of similar devices online that may suit you better if you decide to try this.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Hey Larry,
It looks like you will either have to modify your car radio or purchase a new one. I would reccomend using a kit like this one for modifiying your radio. Replacing the radio may prove to be difficult if you would rather not use one of these kits. Really, it is just personal preference.
Hope this helps,
Tanner
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Larry Yurdin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 111
