주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2264 질문 전체 보기
Back Camera + Flashlight don´t work
Hello,
i have bought an Iphone 7 128 gb black where the seller says the back Camera is not working. So when i get the Iphone i checked all and all worked, only the back Camera and the flashlight for it don´t work. (Face time Camera works well)
I replaced the Camera with a working camera from another iphone to test it and have also the same problem. I take the motherboard also into another iphone to test if there is something wrong with the flexcable on the back, but nothing changed.
So is there a chip or something else who turns the light and camera on?
kindly regards from austria.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
There is a chip on the motherboard that controlls the camera and flash. you will have to replace that chip to get the camera working, it is a very difficult process with high risk for first timers.
Hello, do you have a pic where i find this controller? regards
The camera and flash uses different chips,DA3 chip controls the flash while SN61280D controls the Camera. It's a 16 pins connector chip.
댓글 달기
답변 1개
선택된 답변
There is some circuitry responsible for powering the back camera and flash, this may be what's at fault here. I'm not clear on which motherboard you tried in which phone (lost in the translation ;>). Have you tried a known working logic board in the phone that has the flash and camera issue? If you have and the problem is still there, then your flash flexand camera may be damaged. If the replacement logic board works then your problem is on the original logic board and this will require a micro-soldering repair.
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
귀하의 답변을 추가하세요
Josef 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 20,981
