주요 콘텐츠로 건너뛰기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/64GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
1049 질문 전체 보기
Error 9: iPhone SE won't restore after attempted update to 11.3
Two days ago, iOS 11.3 came out, so I figured I would update both iPhones in the house. Everything went fine with my 7 Plus, but after attempting the exact same procedure on an (unfortunately out of warranty) iPhone SE, the phone, for reasons unbeknownst to me, just froze in the middle of the process and displayed the "Connect to iTunes" screen. We have a backup, so I figured I'd just plug it into my Mac and restore from iCloud after everything was ready. Unfortunately, I've been getting error 9 on iTunes over and over, even though I've already tried multiple cables and computers, both Windows and Mac. (Don't even get me started on going into DFU mode.) !&&*, I've even tried plugging earbuds on, pressing down the area where the memory chip is placed (which, looking back now, would never really work, since it wasn't really open) and even "mildly" heating the back of the phone with a hairdryer (yes I know that's all kinds of wrong but I was dESPERATE), all to no avail.
According to my searches in multiple languages, this is most probably a hardware issue (NAND/IC chip?), but I want to make sure I exhaust my software options before shelling out any cash or sending it off to be repaired. Everything was working fine before the update, and it's never been opened before...
Sorry for the long text and pLEASE SAVE MY SOUL
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개
i also have this problem but mine is an error 28
Crazy, I haven't had the time to go figure the actual problem with my phone... it's been laying around for over 2 weeks now. Let me know if you ever find out.
댓글 달기
답변 1개
선택된 답변
Have you tried DFU mode? It's obvious you aren't happy about it but it's unclear from your question if you successfully tried DFU.
You have pretty much tried everything I would normally suggest from a DIY perspective. It's probably not a NAND issue however because that is more associated with the iPhone 6 series and the iPhone SE is more like an iPhone 6S from a circuit perspective. It's probably more related to a faulty Tristar IC on the logic board.
Either way, this will most likely require a micro-soldering repair.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
I did try putting the phone into DFU mode... multiple times ☹️ I had seen a potential solution on YouTube that involved physically cracking the phone open and pressing the NAND chip down as the restore went on, but at least now I know what not to do. (Well, now that I think of it, that sounds like a bad idea from the very beginning.) And you’re right, they were all the same model on the videos - the 6.
I’ll probably just send it off to be repaired. Thanks a lot!!
댓글 달기
귀하의 답변을 추가하세요
Antônio 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 1,622
