주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Pinout for Charing port
Hey all does anyone have a pin out of the usb charging port on the Ipad Mini 2?
https://s19.postimg.org/6t657c3jn/Screen...
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Is this on logic board?, if the pin is missing u need scratch, to make new pin
i dont even know what pin(s) are needed - thats what i need to find out.
댓글 달기
답변 1개
선택된 해법
Here is a image that shows where you have to connect the missing pad. Look for the red :>)
이 답변이 도움이 되었나요?
점수 3
댓글 3개:
So the red dot is also power from the usb connector since it seems I'm missing those 2 red pins?
Also, what would the ground be located?
To find ground, just put one multimeter probe on a shield and then use the other probe to check the pins individually. Then look for 0 Ohm readings or a beep in continuity mode.
Thanks @Minho. This pin for power would be the one that allows it to be charged as well, correct?
댓글 달기
답변을 추가하세요
David 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 15
지난 30일: 26
전체 시간: 594
