Crank but don't start
I have a 2004 Pontiac Grand AM that cranks but does not start. We have replaced the fuel filter, fuel pump, fuel regulator, and fuel pump switch but it still does not start. Can you send me any more advise????????
좋은 질문입니까?
좋은 질문입니까?
Get your car scanned for codes first off. Always do that before replacing anything.
I'd bet though it is probably your crank angle sensor, but get it scanned first.
이 답변이 도움이 되었나요?
u must check engines before start ur car thats very imporant ur car before on road grab some sensor battery and check on battery on your car maybe is low or high and also dont forget about the oli its may low oil if oil is empty the car won’t started
이 답변이 도움이 되었나요?
We are having exact same problem. Only code is O2 sensor, replaced both, still won't start code still says O2 sensor
이 답변이 도움이 되었나요?
지난 24시간: 2
지난 7일: 5
지난 30일: 22
전체 시간: 5,606
Please help ???????
Jimmy Samora 의
After everything I had told you I was going to replace the crankshaft angle sensor and disconnected the negative on the battery after some delays I connected the battery back up and just out of curiosity tried to start the car and of all things the car started. Can you give me a opinion on why the car started.
Jimmy Samora 의
That worked for me! Just disconnected the negative on the battery for a little while and reconnected it. Thanks! 2005 Grand Am
Whitey Stange 의
