주요 콘텐츠로 건너뛰기
PowerPC G5 프로세서를 사용하는 iMac G5는 2004년에 처음 출시되었습니다.
20 질문 전체 보기
Which Mac do I have?
The serial numbers are rubbed off
How do I figure out which one I have?
Power supply is broken can’t turn it on.
Thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
It’s rubbed off I can’t read it
댓글 달기
답변 2개
선택된 해법
Give us the Model Number and everything on the back of the stand.
Update (04/03/2018)
If your ports are horizontal in a straight line,you have an iMac Early/Mid/Late 2006. Otherwise if they are in a vertical line,you have an iMac G5.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
가장 유용한 답변
Look on the bottom of the stand. That should give you a model number and a EMC number. It also has the serial number.
The serial number should also be there. You can plug that number in at this link for the complete story on your iMac:
https://everymac.com/ultimate-mac-lookup...
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
He said the SN was rubbed off. The position of the ports should let him know whether it's an iMac G5 or an iMac Early/Mid/Late 2006.
Thx!! I took a pic of the bottom of computer and I zoomed in and I figured out just the serial number. I put it in that link and I have my info! Thank you!
댓글 달기
답변을 추가하세요
Az Brian Montee 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 233
