주요 콘텐츠로 건너뛰기
2017년 9월 22일 출시. Model A1863, A1905. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
873 질문 전체 보기
iPhone 8 not "showing"a charge after the replacement of LCD?
The LCD was replaced. Now the phone is actually charging but no showing the charge. Everything is working. It shows 1% but it actually is charged. Now, it does power on and off on its own? Left it unplugged for two days. It was charged when I came back to check on the process but still showing 1%. Any thoughts?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 5개
was the battery disconnected during the repair and reconnected properly post repair?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Same here.. seems to be related to iPhone 8 & IOS 11.3..,
Michelle what iOS are you using? 11.3 perhaps?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
If your battery is connected correctly as it should be then its related to IOS 11.3 software issues
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Would not be the first problem iphone 8 has with replacement screens on ios 11.3, so could be the ios problem
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hello, i have this problem too... i change lcd for some OEM lcd and not work touch, now i make update 11.3.1 and touch work... but battery is still 0% and not showing the charging bold... when i connect to charger come first few seconds +/- 1100mA, after strarting OS come down on 200-380mA.... i inspect the board and like 2mm from battery connector missing one small part looks like capacitor etc.... i think this is the ptoblem.... can you tell me some good man what is the part? :)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
7michele 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 220
