My charger doesn't charge.
After going down from lack of battery, my tablet won't charge. The charger Light doesn't turn on, and I need some solution that doesn't involve buying a new one or throwing everything against the wall...
좋은 질문 입니까?
좋은 질문 입니까?
@gc05 you could check your charger with a multimeter first to make sure that it is working. If it is then you are possibly having issues with either the charging port Microsoft Surface Charging Port Replacement or the battery. If your battery is depleted or discharged below the charging threshold it will no longer accept a charge. Replace the battery and see if that works. Microsoft Surface Battery Pack Replacement
안내서
난이도:
운영
5 - 10 minutes
안내서
난이도:
운영
15 - 30 minutes
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 6
30일 전: 19
전체 시간: 25,090
댓글 1개
Just tested with a multimeter, and apparently the charger is working...
The problem must be in the battery.
Gil Cancela 의
