주요 콘텐츠로 건너뛰기
기기 수리 작업 관련 기술에 대하여 알아보십시오.
87 질문 전체 보기
What kind of adhesive should I use for display assembly?
DISCLAIMER: I haven't found any article about this so i make my own.
What kind of adhesive should you use to connect display assembly to phone's frame?
I believe that its some kind of silicon that is modified in a way that will melt under heat to make disassembly easier nor it doesn't seem like 100% silicon to me..
Thanks for any help! :)
- DK
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
iPhones prior to the iPhone 6S do not need adhesive. There are some pre-cut adhesive kits available on iFixit and other websites. You''ll also find similar kits for other models and Android phones.
If you don't want to buy pre-cut kits, you can get Tesa Tape and cut to length. This saves money but takes more time and when the adhesive also doubles as water resistant seal, you're better off with pre-cut.
The same applies to iPads. Don't use the tape that comes pre-installed on most digitizers, it's usually garbage. You can get pre-cut tape from BowlerTech; they use 3M tape but it works really well too.
iPhone 6s Display Assembly Adhesive 이미지
상품
Tesa 61395 Tape 이미지
상품
Tesa 61395 Tape
$5.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Can't you recommend me something universal for Aluminium to glass adhesive? I don't really wanna use tape nor assembly kit. Ideally i want to make my own silicon based assembly kit from specified compound.
Thanks for any help,
- DK
댓글 달기
Do you mean Iphone LCDs to frames. Are you refurbishing LCDs or do you mean Samsung LCDs to phone chassis. ?
Need a bit more information. Different adhesive for different processes.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Isn't there something universal? its usually glass to aluminium which shoudn't make a difference in compound.. (i think)
Or can't you give me a source where i can find those adhesives? I coudn't find them on ifixit other then prebuilt assembly kits.
Like for now i need that for OnePlus 2. I used some from the internet, but it just makes things worse like it expands overtime and make display crack, etc..
thanks for any help,
- DK
댓글 달기
귀하의 답변을 추가하세요
David M. Košecký 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 75
