주요 콘텐츠로 건너뛰기
An HP desktop computer released in 2008.
12 질문 전체 보기
Why my computer when start has many tat tat sounds and not working is
HP dest top computer
Update (04/16/2018)
Can my desttop the ram problem ? the mouse arrow got stuck and I pressed power button half way a min, shutdown desttop computer restart got problem already window 7 not start property!..
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
Hi @kkchan02 ,
Try using the HP SMART. HDD diagnostic software found in the BIOS setup area, to test if the HDD is OK.
As @slagle stated it sounds as though the HDD is failing or has failed.
If it has failed, you cannot repair it, you can only replace it. Hopefully you have backups of your data.
Update (04/16/2018)
Hi @kkchan02 ,
Have you done the diagnostics on the HDD? You haven't said. You really should try it
Download this (select Ver. 7.5 Windows Free Edition) to a USB and boot the PC from the USB to test RAM. If PC boots OK and tests pass then RAM is not the problem.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I think it might be the hard drive might be having a Read and write head crash problem
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
No not solved, the mouse arrow not moving got stuck...so I pressed the power off button half way wait for half miniute ,PC start shutdown, when re-start computer not working asking to press F1 key etc,later PC still cannot boot up and I again press power key half way for a while PC shutdown ,later I again pressed the power start button , this "Tat tat" sounds came out ....any guru can give idea how to repair it...?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
chan k k 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 9
전체 시간: 135
