HL-4150CDN Jam Rear / Close fFuser Door errors
Hi, I have a HL-4150CDN that printed fine for about 10000 pages. One day it had a paper jam. I removed the jammed paper and it has been stuck on "jam rear" error every since. When I open the rear door the error switches to close fuser door. I have dissembeled all the large components several times and run card stock through the fuser and the pick up rollers. I can see no paper anywhere. I also cannot see the sensor that would set the error. Like most times the manual is vague on this topic. It basically says if there is no paper replace the PCB. I want to make sure there is no paper covering a sensor. Has anyone had this problem before and could someone give me the name and location of these sensors that could be causing this problem?
Thanks in advance Rob
좋은 질문 입니까?
Have you tried to do the most basic thing ever, restart it?
If yes, then you could try to remove all paper, ink, etc, and go bit by bit, every step carefully watching for errors. (In some cases this might help),
or if you only have the Jammed Door issue, check for any damage on the door and the sensor and if it's all correctly positioned.
Lena Fox 의
