주요 콘텐츠로 건너뛰기
2009년 중반기 모델 A1278 / 2.26 or 2.53 GHz Core 2 Duo 프로세서 EMC 2326
745 질문 전체 보기
My green dim light on my charger?
My Mac book pro mid 2009 version 's charger started mis behaving just of recent
When I plug it to the a supply a dim green light shows on the macsafe head of the charger but when I plug it on the machine the light goes off
If it's connected to the power supply and I touch it with my hands, the dim green light becomes brighter but it goes off when I plug it to the pc...Please help me I really need this machine for school
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Have you checked if the cable is not damaged, or that the charging port is clean etc?
I would check the onboard battery tester to see how much charge your battery has. If you can download this app: CoconutBattery take a screenshot of the main window and post it here for us to see 기존 질문에 이미지 추가하기 That way we can see how the battery looks and the charging logic inside your system.
댓글 달기
답변 1개
가장 유용한 답변
Not much you can do here other than replace the MagSafe charger. A dim charger LED (Green or Amber) thats not even connected to the system tells me the charger is bad. In fact using it could harm your system!
Review this great Apple T/N: Apple Portables: Troubleshooting MagSafe adapters Make sure your MagSafe connector is not damaged or dirty on your system and you'll need to get a new charger - 60W MagSafe power adapter for your system. I do recommend you buy the unit from either an Apple Store or Apple online as there are a lot of fakes that can hurt your system (and you) Lacking safety features, cheap MacBook chargers create big sparks
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
zumbi calvin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 24
전체 시간: 5,049
