주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Stuck in headphone mode after lightning port replacement
A customer had snapped of their headphones in the audio jack on their iPhone 6. I replaced the whole lightning connector and headphone jack but it is still stuck in headphone mode. Headphones work whilst plugged in but it will not switch back to normal mode. Any suggestions?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
you likely have a short in your new component. disconnect the charge flex from the motherboard, and see if it is still in headphone mode.
1) if it IS IN HEADPHONE MODE, then you likely have a board short from mishandling.
2) If it ISNT IN HEADPHONE MODE, then you likely have a flex issue, and you will need to re-replace the flex.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Hi,Thanks for this info. I have a similar problem and indeed the phone remains in headphone mode when the flex is disconnected. Is this then a problem with the connector on the board, you think? Any suggestions on what to do then?
Many thanks!
Is there a fix for when the iPhone stays in headphone mode even when the flex cable is disconnected?
댓글 달기
is it still stuck in headphone mode when no charge port is connected?
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Yes it is. The headphones work, even connected it to Bluetooth headphones but still stuck in headphone mode
When I say charge port connected I meant the ribbon cable from the logic board.
댓글 달기
귀하의 답변을 추가하세요
Andy Hilder 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 965
