Black Screen After Screen Repair
I have just fixed an iPhone 6's screen for a Cutomer. And the screen is black. It works because iTunes recognises it.
Tried the old screen and also another screen and none of the 3 screens work.
좋은 질문 입니까?
좋은 질문 입니까?
You may have blown the backlight circuit on the logic board. To be certain, shine a bright light on the screen after you connect it to an iTunes enabled computer. If you see a dim image, then the backlight circuit is damaged. This will require a micro-soldering repair.
해당 답변은 도움이 되었습니까?
That's the thing, the display shows nothing! Yet iTunes recognises the phone. I have no idea what the issue could be.
Then you will need to look at the LCM Driver circuit (Chestnut).
Take Diode Mode readings of the FPC's and compare to 1st image, check Filters for continuity...For backlight, pay attention to image 2, and for image, you can start with 3 - 5, but may also find LCM Reset, Photon alive, etc while looking through diode mode readings if off...
해당 답변은 도움이 되었습니까?
sounds like you blew the backlight 99% of the time that happens because the battery was not disconnected during the repair
해당 답변은 도움이 되었습니까?
Oh crap! How do I fix that?
you have to change the filter are you good with microsoldering?
I'm not good with it no. I don't even have the right equipment
where are you located? check shops around you or you can just send it in
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 123
