주요 콘텐츠로 건너뛰기
7.9 inch display / Model A1455 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
30 질문 전체 보기
My iPad mini still won’t turn on after battery replacement
I bought the battery and followed all of the instructions per the ifixit’s website and my iPad mini still is not working. What is my next step?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
It was the same issue when I bought the new battery. My iPad all of a sudden stopped working. I did all that I could for it to turn it on. I tried all the resets .So I bought the new battery and still nothing.
Just off the suggestions you game number 2 would be it “If the iPad was not working before your repair attempt and you thought a new battery would revive it, then your iPad was probably suffering from something else”.
댓글 달기
답변 2개
선택된 답변
What was the original problem that led you to buy a replacement battery? Was the iPad working before you attempted the repair?
Once you give us more details, we'll be able to help just remember that this site is not staffed with iFixit personnel but rather volunteers who help out fellow DIY fixers like yourself.
Here are a few ideas:
  1. If the iPad was working well before but the battery life was poor, then you either have a defective battery or something went wrong during the repair. If you have access to a multimeter, you could try to measure the voltage directly at the battery terminals. You need to have >3V for the device to boot. Leaving the battery on charge overnight may do the trick here. If you have access to a USB Ammeter, you could use that to determine if the device is really drawing current when it says it's charging.
  2. If the iPad was not working before your repair attempt and you thought a new battery would revive it, then your iPad was probably suffering from something else.
Let us know and we can help you further.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
It wouldn't turn on so I thought the battery was done
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Tiffany Horton 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 12
전체 시간: 1,435
