주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model A1661, A1784, 또는 A1785. 32, 128 또는 256 GB 환경 설정 / 로즈 골드, 금색, 은색, 검정색, 칠흑색 및 (Product)빨간색으로 제공됩니다.
1364 질문 전체 보기
Ear Speaker and Front Camera working on and off
I have an iPhone 7 plus that I recently repaired that the ear speaker works randomly and the front camera is very slow at coming up and/or sometimes doesn't work in apps such as snapchat. This iPhone has been fixed previously and has been working fine.
Now I've replaced the front camera and speaker with a known working original with the same results. I also uncovered another issue. The phone will get stuck on the Apple logo after rebooting and will only boot normally after I do a hard reset. I tried different batteries and a different front camera flex with the same result. At this point Im scared to update to 11.3.1 or even restore it, because I'm afraid it wont boot properly and brick the phone
Any words of wisdom before the customer makes an insurance claim? Is this maybe a software issue and not a hardware issue?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
The iPhone 7 series of devices suffers from issues with the Baseband IC, Audio IC and weak traces on the pcb which crack and break. It is a similar design flaw to the iPhone 6 Plus, known as Touch Disease. On the iPhone 7 series, the weak traces are underneath the Audio IC.
In many cases an internal short within the Baseband IC causes the boot looping, which unfortunately, is not repairable because the Baseband is code locked to the logic board. It can also be caused by a broken trace underneath the Audio IC. Replacing the Audio IC and strengthening the weak trace with a micro-jumper can repair this.
If you are curious about the technical nature of these failures, you can listen to this video from Jessa and this one from Jason at STS, they go into a lot of detail regarding this issue. It could be BB or Audio but the info in the video should help you figure out which one.
해당 답변은 도움이 되었습니까?
점수 3
댓글 4개:
Thanks for the info. I will definitely look into this further. Is this something that could have been caused by me? Im extremely careful with removing the flex. The customer did admit to getting some water in the area where the flex connects although there is no visible water damage.
I doubt you (an experienced tech) damaged multiple flexes...
Im going to close this and accept your answer. The videos you linked are the exact symptoms Im having. Thanks again.
Great! Good luck on the fix.
댓글 달기
귀하의 답변을 추가하세요
Brian Wood 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 2
전체 시간: 573
