주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
iTunes Error code 14 - Phone Bricked
This all started yesterday, I had bought an iPhone 7 off eBay for $320 photos looked legit, showed it working with no iCloud, so I hopped on it and bought it.
Well, I get it charged up and, half the icons are stuck on waiting (the person probably updated it and didn't let it fully finish?). So go into settings, it's on iOS 11.2.5 so I figured,
I'm just going to reset it because that will probably clear the waiting icon issue junk, I tap "Erase All Content and Settings"... nothing. So I tap it a couple more times.. nothing, so I tap "Reset all Settings" and it does it. Cool.
It froze ~half way through, so I hold power and volume down button to restart, and it's in recovery mode. Fine, I'll restore through iTunes, no problem.
Extracts the software... Restoring phone... Apple logo on screen. Then Bam!
Error 14. Phone's stuck at Apple logo with the loading bar anywhere from like 1% to 50% across.
OK, different cable. Error 14
Different USB ports. Error 14
Uninstalled iTunes and reinstalled. Error 14
Hackintosh Laptop. Error 14
Turned off all the Windows Defender junk. Error 14
DFU Mode. Error 14
I'm not sure what more I can do, I contacted the eBay seller and they say it's my fault because I "Tampered" with the software. There's not an Apple Store for 90 miles. Since it's used, to send it to Apple would cost $330, which is more than what I paid.
Edit/Update: 5/29 : Had the phone sent to a relative in Las Vegas, he took it to an apple store and they printed of a sheet saying the phone became bricked after trying to restore and throws error 14 indicating a hardware issue, and that I need to either replace the phone or refund with eBay..
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 7개
가장 유용한 답변
Got the exact same thing with my Ipad Mini 4 wifi 16GB, i tried updating/restore on 4 different computers (2 were macbooks)using 3 different official apple USB cables on every single port i could find. Same Error 14 every time. i confirmed i was running the most recent Itunes 12.7.4.80.
I took mine to the apple store yesterday, they tried on 2 different macbooks with several cables and they also got the error 14 everytime.
They basically told me i now have a brick and theres nothing they can do since it is out of warranty. They said it maybe the logicboard is bad but couldnt tell me for certain and wont take it apart to see the problem.
Took it to a local 3rd party technician, confirmed i also had a brick. so now i'm contemplating if its worth trying to get a logicboard or just sell for parts.
sorry man. hope yours can get fixed some how but if its the same issue as mine.... :(
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
didd you lost data
댓글 달기
Don't restore won't work, plug in and update it if you can if not download the firmware for that device and shift click restore or update and select that firmware you downloaded and install it
이 답변이 도움이 되었나요?
점수 0
댓글 4개:
Tried shift clicking update and using the ipsw, still error 14.
That's odd sounds like it's getting hung up on something then
Have you tried restoring via iTunes on a desktop computer? Not sure whether you are doing this on a laptop or not.
I know my Surface Pro 3 doesn't have a good USB port because it just keeps toggling the connection for apple devices.
I am using a desktop, I have also tried using my Hackintosh laptop, once again, Error 14.
댓글 달기
Same problem here on an iPhone 7. Changed U2 tristar, reprogrammed nand and still, error 14.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have aslo the same problem with my iphone 7 plus.
actully i am a technician so i decides to fix my phone because its not software issue. Its a hardware problem
  1. Changed the nand no success
  2. checked nand pada each nand pad have good impidance
  3. changed nand eeprom
  4. checked usb track tristar also is good
  5. i don’t know what should i do to fix it
  6. here is crash log
  7. ( [10:24:21.0016] ==== device restore output ====
  8. [10:24:21.0016] (null)
  9. [10:24:21.0016] ==== end of device restore output ====
  10. [10:24:21.0016] AMRAuthInstallDeletePersonalizedBundle
  11. [10:24:21.0110] <Restore Device 0000000054D58550>: Restore failed (result = 14)
  12. [10:24:21.0110] Finished RestoreOS Restore Phase: Failed
  13. [10:24:21.0110] State Machine Dump, status:ERROR - [state:DFU remaining-cycles:1] -> [state:Recovery remaining-cycles:0] -> [state:RestoreOS remaining-cycles:0 (current state)]
  14. [10:24:21.0110] Changing state from 'Restoring' to 'Error'
  15. [10:24:21.0110] State is now set to error
  16. [10:24:21.0110] Restore completed, status:14
  17. [10:24:21.0110] Restore Checkpoint Fingerprint: 065B.000E
  18. [10:24:21.0110] Failure Description:
  19. [10:24:21.0110] Depth:0 Code:-1 Error:AMRestorePerformRestoreModeRestoreWithError failed with error: 14
  20. [10:24:21.0110] Depth:1 Code:14 Error:Failed to handle message type StatusMsg
  21. [10:24:21.0110] Depth:2 Code:14 Error:failed to restore APFS image )
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
so did you fix it
댓글 달기
Try restoring with the screen unplugged. If that doesn’t work, could be IC chip.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
This is pretty late, but I got the phone the an Apple store and they gave me a paper saying the phone had some hardware issue and that I should file a refund with eBay or the seller. Which I did, and got my money back.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
but were you able getting your data back?
It was a used phone from eBay, so I never lost any data.
댓글 달기
Has this Error 14 on an iPhone SE. The phone was stuck on the Restore screen, Connect to iTunes. This was due to a failed jailbreak attempt with unc0ver on iOS 11.3. Tried to restore it 10’s of times. Even in DFU mode. Upgraded iTunes. Tried different cables and USB ports. Tried to disable antivirus. Disabled firewall. None of these got it to work.
Every time the status bar on the iPhone screen went to a percentage of restored then iTunes said Error 14. Tried this with iOS 12.3. Then Apple stopped signing it. Tried it with iOS 13.0. Same problem. Tried it with iOS13.1. Same problem. In many of these cases I had downloaded the IPSW and used SHIFT+Restore to select it (saved having iTunes download a 3GB file to fail every tme).
Tried with iOS 13.2. Tried with a downloaded IPSW, which failed. Another time instead of SHIFT+Restore I let iTunes download the IPSW. Using a non-genuine cheap lightning cable. Antivirus on. This time it worked!
To anyone who thinks the phone is bricked (and knows it wasn’t water damaged or dropped etc), I would just say try many, many times and it might work eventually.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Hi Scripter
How I can I get an older IOS version?
Please can you share the link for the old IOS version (signed version)
Thanks
댓글 달기
답변을 추가하세요
Allen Wilson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 7
지난 30일: 34
전체 시간: 16,926
