My CD won’t play it just says Reading
I played two cds on it and when I put the third it stopped working when I put a Cd in it Just says reading
좋은 질문입니까?
좋은 질문입니까?
I had the same problem. When I put a CD in, it kept saying “reading”. Without taking whole thing apart, I just push (gently) the laser reader to the very left end. It is working now!!!
이 답변이 도움이 되었나요?
Otis Chen's solution also worked on my case. Thank you.
It worked for me two thank u so much!!
Also worked for me - if only people knew this secret. Imagine how many people have thrown away their Sony Model No. ZS-RS60BT !! Wow - thanks
Thank you Otis Chen!!!
This worked for me,too.Just push a little and softly.
Kenny lodeon you were of course only playing one CD at a time and removed it before playing another one. Right? This sounds like a dirty laser assembly. You can try one of the commercially available laser lens cleaners (available in most stores). If that does not work you will have to possibly disassemble it and clean the assembly with a microfiber cloth. Ultimately you may have to replace the laser lens assembly Difficulty with all this is that there are no disassembly guides just yet nor are parts readily available.
이 답변이 도움이 되었나요?
I have had 2 of these units both stopped playing cds the last one was out of warranty. If you take all the screwa out and open it up you can get hold of the slide for the laser reader and move it back and forth a few times, it should start playing again
Using a glasses cloth just moving the lens reader arm back and fourth gently (no need to unscrew for access) got the CD player to work again.
이 답변이 도움이 되었나요?
Wonderful! I got a glass cleaner cloth and gently slid the laser/reader to the right and back to the left. I hit the CD button and after trying to read it indicated "NO CD". I put a CD in and it read it and after hitting play, it played the CD as though there had not been a problem at all. Thank you!
지난 24시간: 10
지난 7일: 59
지난 30일: 261
전체 시간: 9,532
댓글 1개
It would seem unless the CD is brand spanking new it won't play correctly... Heat may be a problem too, who knows? PITA.
Dave Ulmer 의
