주요 콘텐츠로 건너뛰기
Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
52 질문 전체 보기
Where is the GPS in CDMA iPad?
The Broadcom BCM4751 is clearly identified in the iPad 2 GSM breakdown. What chip provides GPS in the CDMA iPad 2?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
가장 유용한 답변
from here The key differences to note are that the CDMA model has an additional antenna compared to the GSM variety and it also uses a Qualcomm Gobi dual-mode radio with integrated GPS that actually supports both CDMA and GSM, but the GSM compatibility is unused by the iPad. And this The GSM iPad 2′s 3G radio has an Intel 36My1EF with 128MB of Numonyx NOR flash and Elpida Mobile DDR SDRAM, Infineon 337Se833 Baseband Processor, Skyworks TriQuint Transmit Modules, and Infineon 338S0626 GSM/W-CDMA Transceiver. It also includes a Broadcom BCM4751 Integrated Monolithic GPS Receiver, which is an update from the BCM4750 found in the GSM iPhone 4. from here http://wi-fi.me/2011/03/30/comparison-of... So,yes cityzen is right it is integrated.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
+ really nice work
Thanks - very helpful.
댓글 달기
Apparently, the Qualcomm MDM6600 performs that function. At least, that is what everything thinks (as shown by a web search).
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
John OShaughnessy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 2,373
