주요 콘텐츠로 건너뛰기
Dishwasher by Bosch identifiable by the model number SHU5315UC-06 or SHU5315UC/06.
11 질문 전체 보기
led display and lights do not work
Have a Bosh logixx dishwasher, It will function by the power button. So will do the job and turn itself off etc........It is meant to have a count down timer on the led display etc but the display and lights are not working.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
Have you tried to dissemble it and check pcb? Connectors and fuses especially?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I could not find a manuel guide with a picture...do you know where the fuse are located?
I was thinking it could be a fuse but also need the type of fuse
댓글 달기
no replaceable fuse on this unit . check connections from the pcb to the lights or replace pcb
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Mark Marriner 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 8
전체 시간: 1,118
