주요 콘텐츠로 건너뛰기
3MB 공유 L3 캐시 2.5 GHz 듀얼-코어 Intel Core i5 프로세서 (Turbo Boost 최대 3.1 GHz).
265 질문 전체 보기
Sound distortion from the speakers on MacBook Pro (Retina Late 2012)
So I have this MacBook Pro for about 2 years and it seems that both of the internal speakers are providing distortion to the point that I can't even use them anymore I have to use the equalizer to turn the bass all down so that I can hear it a little.
I read a comment somewhere that they can be fixed without needing to replace them. I wanna know if there is the guide or a way which I can follow to try to get them fixed without needing for expensive replacement as it seems that both of the speakers required replaced or fix.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
Hi,
Any did you find any work around?
댓글 달기
답변 1개
가장 유용한 답변
See if the problem persists if you log on as a guest user when booting up and let us know.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Problem still persist. The sound even distort when its botting up. That means its not the software problem. Moreover I have tried reseting the SMC and P. Ram but this problem remains the same. I'm sure that its the speakers causing this.
댓글 달기
귀하의 답변을 추가하세요
azn 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 2,158
