주요 콘텐츠로 건너뛰기
The Kenmore 90 Series is a washing machine manufactured by Kenmore.
Agitates while filling and rinses while spinning
My 6 yr old Kenmore washer has started agitating while filling and pouring water while spinning. I've had to leave the lid open initially and then turn the water off during the spin cycle. Thank you for your help.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
The problem could be a faulty timer or pressure switch. I recommend unplugging the washer and opening the console. I have provided you with the instructions for accessing the console below. Then locate the pressure switch. It is the part that has the small hose connected to it. Once you find the pressure switch, unplug the wires to in. then plug the washer back in and start a wash cycle. If the washer does not do anything, the pressure switch needs to be replaced. If the motor still runs or makes noise the timer needs to be replaced.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Please clarify "unplug the wires to in" I don't understand. thanks
@Ed Castle
I think it is a typo and it should say "...find the pressure switch, unplug the wires to it."
What is the model number of your washer?
댓글 달기
답변을 추가하세요
Marc 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 7
전체 시간: 1,894
