주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
iPhone screen is unresponsive and sometimes works
I currently am using an iPhone 5s. Last week, I have been experiencing problems with my iPhone 5s (I know, its really old, but I just love this phone way too much). Anyways, the problem started out where the screen would randomly freeze up, but the home and lock buttons would work perfectly fine. Siri is working fine too. To fix this problem, I would simply lock the phone and re-unlock it and it would work completely normal. However, over the course of the week, the lock and unlock method stopped working, and whenever I use my touch ID to unlock my phone, I am stuck on the home screen unable to press apps or to do anything else. If I leave my phone locked for a while and then re-unlock it, then the screen is responsive for a couple of minutes, but again stops working and becomes unresponsive. Adding on to that, I've restarted my phone multiple times -- it would be responsive for a couple of minutes, but then stops working again. The phone is mildly cracked, but that didn't hinder the screen response before.
After some research, I've come to the conclusion that maybe my digitizer and the LCD screen aren't connected properly, or if the connections were broken due to dropping the phone a lot. Would getting my screen replaced help fix this problem, or are there any other solutions?
Adding on: I have vertical blue/ red lines on my phone
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
It's probably the screen. Unfortunately, the only way to properly troubleshoot an iPhone is to try known-good parts. So in your case, you will have to try a new replacement screen, preferably one from a reputable supplier. You can follow this guide.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Lilly Johnson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 1,574
