주요 콘텐츠로 건너뛰기
Apple 주문 번호 MC007LL/A / 27" 2560x1440 픽셀 화면
78 질문 전체 보기
How I can set-up 2 screens to my MacBook Pro
Sorry, I keep asking questions. But Mr Mayer is the guru. Without him I would have spent a fortune. And that fortune would not have solved the problem. Strongly recommend Mr Mayer.
Can you advise how I can set-up 2 screens to my MacBook Pro. The first being the display (it only has 3 USB ports, no HDMI) and a monitor with VGA and HDMI ports. Note: The MacBook does not have a HDMI port. Any advice.
Links to parts to purchase would be perfect.
Thanks again. You have saved me from spending a fortune.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
Please tell us exactly which MacBook Pro you have. Thank you for the kudos ;-)
Hi, thanks in advance for your help. I have a MacBook Pro A1286. Linked to a Tbolt Display A1316 (only USB connections) and an Asus monitor with HDMI and VGA connection. Hope that you can help. Thanks again.
Hello. Can I reach Mr Mayer here? You gave me great information about my tb display screen. I still need to find the right solution. Shall I post it here or screen comes on and then off
Thank you
댓글 달기
답변 1개
선택된 답변
the older macbook pros require a mini displayport adapter, for the one with vga, you will need this: https://www.apple.com/shop/product/MB572... and for the other one, the usb ports are for data, not video, it might not even be possible to use two screens on your model, and that other one would require a mini displayport cable, which should have been included
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thank you for your help. I already have the adapter. It works fine when my Mac. It also works fine with the Mac display cable. Is there an adapter that holds both so that I can share screens, an adapter for two Mini Display Ports for the MacBook. Maybe the model is too old to support this. Thanks
댓글 달기
귀하의 답변을 추가하세요
Fm34b 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 5
전체 시간: 111
