주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Screen Replacement Problem wigh frame and LCD
I have replaced many screens before and they have worked great but i have had a couple what fit but the bottom right doesnt really clip into place an the is light at the right side of screen, also the is like a white dot at the top of screen on LCD, The screen is not damaged in anyway but why do these problems occur? I have sent the screen back anyways.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Assuming the housings weren’t bent or warped, then you may just be getting low(lower) quality screens. Cheap screens are notorious for poor fit, cheap materials and poor assembly (dust between the LCD and Backlight). If you are buying from a reputable or quality supplier, them talk to them about the issue and they should make things good.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Adam Powell 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 68
