주요 콘텐츠로 건너뛰기
Released in the early 2010s, the Asus K43SA is a 14-inch laptop with a 2nd-generation Intel Core processor and an AMD Radeon graphics card.
6 질문 전체 보기
Why is my computer suddenly shutdown?
I Have an Asus K45VD with a mother board LA-8224P.
After some time it suddenly shuts down, no questions asked.
It boots prefectly.
Works fine for a few hours.
Then black screen, and I have to turn it on normally.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Hi,
What OS is installed, Win7, 8.1, 10?
Check in Event Viewer to see if there are any critical/error/warning events listed at the time of shutdown that may give a clue as to what is happening.
It may also be a simple heat problem with the hardware.
Check that the laptop's fan vent is clear and unobstructed.
It may be that the fan needs to be cleaned and the CPU may need to have fresh thermal paste applied.
Here's a link to a video that shows how to disassemble your laptop to gain access to the fan so that it can be cleaned.
Here's a link to the ifixit Asus Laptop K43SA A43SA Thermal compound Replacement guide. I realize that it is not your model but it shows how to clean the fan and remove/apply new thermal paste to the CPU which may be of some help, once you have access to your fan and CPU.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
It may be built to shut down to prevent over heating. If it is a safety thing or if it's getting to hot, you can buy a cooling pad, if it's a laptop. It's also possible that a recent app you installed may be causing it to crash. You may also need to just simply download and install updates
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Brandon Ruiz Vasquez 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 4
전체 시간: 168
