주요 콘텐츠로 건너뛰기
Model A1285 / 8 or 16 GB capacity
206 질문 전체 보기
How do I turn off my iPod nano model A1285/ 8gb?
I know this is silly, but how do I turn it off? Apparently I keep locking it, then I find the battery drained. Is it on when the orange is showing around button on top, or off, or just locked? I guess we lost the manual in the move.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 1개
This question was migrated from http://meta.ifixit.com/.
댓글 달기
답변 8개
가장 유용한 답변
Misha, you really can not turn the off in the conventional way. It does not have an on/off switch. The lock button just locks it from using the buttons/wheel for any input. Orange means its locked. You can put it in standby by pressing down on the play/pause button for a few seconds and the iPod will turn off, meaning it's on standby. To turn it back on you press the play/pause button for a few seconds and it will turn back on. To turn it off completely you need to press down on the center button, then the menu button and it will turn off. Here is the user user guide Good Luck and let us know how it is going.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
My iPod has a menu button on top middle arrows to the left arrows to the right bottom arrows going to the right.My daughter said push arrows on bottom hold and it will shut off did that then when I took it to the gym it was dead .Model BGB
댓글 달기
Hi
I have an apple ipod 8gig Nano.
It refuses to come on, but it does come on when I connect it with my computer or a docking station.
Kindly help me and tell me how do you switch it on if you just want to listen to music with your earphones.
I did hold down the ok button for a minute and still no progress.
Regards
Zunaid
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I have the same exact problem, except that when I connect it to my computer I can only see that the screen is synchronizing, if you found the solution let me know please, I know that your comment is 4 years old lol, but I still wana use my ipod.
댓글 달기
how to open screen lock
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
what screen lock are we talking about? which iPod? Give us more detail so we can try to help.
댓글 달기
yes I do tun on my ipod nano a1285
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Flick the hold switch on and off. That should work.
댓글 달기
Please tell me ow to shut it off model 8gb
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I have a iPod model gig can't shut it off someone gave it to me it's annoying want to use it at the gym thanks .
댓글 달기
Hold down the Play/Pause button until it shuts off, then lock the screen with the switch at the top of the Nano.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
It is quite easy, hold down the play/pause button and it'll turn off just like that.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi,
I am Maneesh. So coming to your question.
Step 1:
press and hold play or pause button on IPod till the display off.
Step 2:
While holding button slide the button on top so you can see orange color.
That’s It You successfully turned off your IPod.
Thank You.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Misha 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 10
30일 전: 43
전체 시간: 32,687
