주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display, 모델 A1502의 2015년 3월 업데이트는 5세대 Intel Core i5 및 i7 프로세서를 포함하며 Force Touch 트랙 패드를 소개합니다.
1185 질문 전체 보기
MacBook Pro Retina Display Water damage Display not working!
I have a Macbook pro Retina Display 13" Early 2015 with water damage and everything works fine except the Display and the Apple logo. Literally everything isight camera, keyboard, trackpad, usbs, charger, battery, speaker, headphone jack, microphone, wifi, bluetooth, hdmi, etc.
In fact I am actually posting this question using the same computer connected to a TV via hdmi.
These are the following things I have already tried to troubleshoot:
  • Hard Reset
  • Resetting the SMC
  • Safe Mode
  • Recovery Mode
  • Clean Install of the OS
  • Hardware diagnostic test. Which gives me an error reference code of VFD001.
  • I also tried to shine light on the screen from the back but nothing shows.
The computer fails to detect an internal display at all as the HDMI only gives me the option "Use as separate display" (No mirror)
I followed some post here on how to clean the logic board and I cleaned it with isopropyl alcohol twice and still no luck. There are no visible signs of corrosion. I however did take several photos of the logic board hoping experts here would be able to help me diagnose the problem.
Logic Board. (If you notice the bottom left liquid contact sensor has turned pink)
Logic Board Bottom Left liquid contact sensor
Back Side of the Board
Display Cable Socket
Display Cable
Something that looked like may have been corrosion at the battery connector? (bottom side). Image After cleaning.
If there is anymore information that could help you diagnose the problem, please let me know.
Update (05/31/2018)
@oldturkey03
I tested for continuity between these points and I got a beep. I guess the fuse is alright. Any advice?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
looks like your board is a 820-4924.
댓글 달기
답변 1개
가장 유용한 답변
@rashids93 start with something simple. Check the backlight fuse and see if it has continuity.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
@oldturkey03
[image|1472677]
Added the image to the original question
Looks like you may have to test around the display connector to see if you get power and signal. Send me an email so I can forward you some instructions etc. My address is on my about page. Just click on my avatar.
댓글 달기
귀하의 답변을 추가하세요
Rashid Shahid 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 664
