iPhone 6 PP1V8 Oscar 0 Volt
Hi,
Iphone 6 connected to power supplay 4V will boot until 0.07a - 0.09a and LOOP.
LCD Blank , Not in Recovery or DFU Mode .
Tested Tristar before and after replace 1V8 - 3V0 - 5V0 Lines Ok.
Tested Tigris 3V0 and 5V0 Lines Ok
No Short on VCC Line
PCB Not Heat
No water damaged.
Due Low power amp Loop i suspect to 1V8 SDRAM.
Start to Test all 1V8 lines and i fund 0V at line PP1V8_OSCAR.
IC - U2203 c2247 and c2248-1 instead of PP1V8_OSCAR has 0V.
IC - U2205 c2270-2 instead of PP1V8_OSCAR has 0V.
IC - U2205 c2272 instead of PP3V0_IMU has 0V.
From where PP1V8_OSCAR is taking power ? While Tristar and Tigris 1.8 are OK
Any Help will be highly appreciated
thanks In Advance
좋은 질문 입니까?
댓글 1개
Thanks but the set is taken by customer...
Regards
Formingus 의
