주요 콘텐츠로 건너뛰기
The Tiida(Versa) hatchback and the Tiida Latio sedan debuted in 2004 in Japan, and in select European countries in 2007.
11 질문 전체 보기
Reverse camera RCA cable
Hi There,
I have panasonic cn-hds625d and need to get a RCA cable for the rear view camera. Please advise what is that slot type called and where it is available. This car is currently in Newzealad and it is an Japan Import car
Sorry. Missed to update the image... adding it now.. Please also where i can get these cables in Newzealand.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
'''++ttsenkumar kumar++''' not quite sure which slot you are talking about. I suppose you are referring to the rear camera slot. You can always post some images of what you are looking for with your question. Use this guide 기존 질문에 이미지 추가하기 for that. That is most likely proprietary and without a proper schematic it will be extremely difficult to source it. I do believe that there is a rear camera kit for your navigation model Check for something like YESFX999101
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thanks Mate... Just added the picture
댓글 달기
답변을 추가하세요
ttsenkumar kumar 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 8
전체 시간: 462
